Few questions before I buy.
Xen
Post by Xen »
I have both a VAG and an ELM interface and both seem to work with the software. Just wondering if I can use this to help diagnose stiff steering (without PAS light) on a Punto MK2. I suspect it might need recalibrating, can this software do it? Also I have A 1.2 Stilo which doesnt flash the indicators when I use the remote central locking. Can I use this software to turn this feature on and reset the service reminder?
Cheers, Matt.
Xen
Re: Few questions before I buy.
Post by Xen »
Sorry, i should also add the steering on the MK2 Punto has obviously been changed recently but I suspect the wrong column has been installed.
EnIgMa
Post by EnIgMa »
you should be able to do everything or almost everthing you said.
Take a look here: http://www.multiecuscan.net/SupportedVehiclesList.aspx and see what's supported.
