Lancia (Chrysler) Ypsilon radio
Thotos
Post by Thotos »
I hadn't used my Ypsilon for about 7 weeks and the battery was TOTALLY flat. I replaced the battery and the car started. All is fine except the radio won't turn on! Multiecuscan claimed the radio was disconnected. So I performed a proxi alignment in the hope that it would reconnect the radio but the radio disappeared altogether. How do I get it to find the radio again?
Re: Lancia (Chrysler) Ypsilon radio
if MES said there was no radio how proxi should have brought it back?
check fuses firstly and do proxi again as now you completely have removed radio from car configuration.
Thotos
Post by Thotos »
I have checked all fuses. Or at least all fuses I can find! This is a Right Hand Drive Chrysler (Lancia) Ypsilon and all Dashboard fuse box locations I can find online don't match my vehicle. There's a fuse box in the engine compartment which I am sure has nothing to do with the radio but I checked every fuse anyway. I also found a fuse box hidden behind the glove compartment which has half the number of fuses than what's online for "dashboard fuse box". So maybe there's another fuse box somewhere so I'll keep looking. But running MES Scan reports "Receiver Radio (NRR) Not Present". Strangely, before performing the Proxi Alignment, the Proxi Info reported "EOL OK" or just "OK" for most items but now reports "Present".
Thotos
Post by Thotos »
Fixed :P
