connection failed KKL/VAG
lubos
Post by lubos »
Car: fiat 500,1.2 8v, 2009
Interface port: K-line/VAG(blue with 4 ports) ...test: succesfull
Connect- failed.. connection failed You need ELM327/OBD key interface to connect this modul
I tried to reset my airbag´s error but here we are.
I also tried scan but nothing appeared.
I had multiecuscan 5.0,4.6,3.1,3.0,1.7..all registered and the same error.Help me please
Re: connection failed KKL/VAG
The 500 is ALL CANBus based. KKL will NOT work! You need an ELM or OBDLink Interface.
lubos
Post by lubos »
After your advice I have bought OBDII interface...it looks like it supports CANbus protocols. (USB V1.5).
So I tried to connect to my car (fiat 500) and any of interfaces didn t work.
So if you could help me with this I would be pleasure.
You do not say what make and type of interface you bought?
There are many cheap Chinese / other devices claiming to be compatible, but they just don't work. See: http://forum.multiecuscan.net/viewtopic.php?f=5&t=1493 for the horror stories.
Suggest you get your interface ELM / OBDLink from one of the approved suppliers: See: https://www.multiecuscan.net/Distributors.aspx
Not only will their kit work but they also provide help if required.
