Difference in the list of Giulia modules...
dusan147
Post by dusan147 »
Version MES 5.0.
When perform "Scan DTC (F12)" or "Scan (F11)", using ELM327 1.4 + adapters 5 and 6, it is evident the list of modules is different in comparison with list of modules in particular sections for Alfa Romeo Giulia 2.2 MultiJet 16V.
Which is reason of this?
Being Merlin and not Arthur!
Re: Difference in the list of Giulia modules...
they are not supported yet.
dusan147
Post by dusan147 »
If they aren't supported how they appear in DTC scan list and how is possible to clean errors connected to these?
chrener
Post by chrener »
Hi!
Which modules do you mean?
dusan147
Post by dusan147 »
Following modules discovered by use of ELM327 and adapters 5 and 6 (nonexistent modules and discovered by MES, but no in Giulia 2.2 MultiJet list on MES site):
Engine / ECM
Bosch EDC17C69 CF6/EOBD Diesel Injection (2.2)[color]
Urea/AdBlue dosing module Continental - nonexistent
Gearbox / DTCM (Drive Train Control Module)
Magna Q4 Transfer Case
Gearbox / TCM/NCA/NCR (Automatic Transmission)
ZF 8HP50/75 Automatic Gearbox
Gearbox / ESM/GSM/NSC (Gearbox Selector Module)
ZF Electronic Gear Shift Module
Gearbox / CDCM (Chassis Domain Control Module)
UNKNOWN/UNSUPPORTED
Errors found: (https://www.dtcdecode.com/Alfa-Romeo/U1706-86)
U1706-86
ABS / ABS/BSM (Brake System Module)
Continental ABS MK C1
Other / DASM (Driver Assistant System Module)
Driver assistant system module (DASM) radar Bosch
Errors found: (https://www.dtcdecode.com/Alfa-Romeo/C141C-86)
C141C-86 - Private CAN between HALF and DASM - Signal/message invalid
Other / HALF (Haptical Lane Feedback Module)
Haptical lane feedback (HALF) camera Bosch
Torque vectoring module (TVM) - nonexistent
Airbag / NAB/ORC (Airbag/Occupant Restraint Module)
Bosch Airbag
Steering Lock TRW - nonexistent
Electric Steering / EPS (Electric Steering Module)
ZF Electric Steering
Amplifier module Ask/Beats - nonexistent
Engine sound enhancement module (ESEM) - nonexistent
Instrument Panel Continental
Dashboard / ETM (Entertainment Telematic Module)
Marelli AlfaConnect Radio/Nav
Dashboard / EMCM (Entertainment multimedia control module)
Multimedia control module (multifunction knob/joystick/touchpad)
Body Computer Marelli (952)
Errors found: (https://www.dtcdecode.com/Alfa-Romeo/U197C-83)
U197C-83 - Error in communication with Automatic transmission - Value of signal protection calculation incorrect
Body / RFHUB (Radio Frequency Hub Module)
Radio frequency hub (RFHUB) Continental
Errors found: (https://www.dtcdecode.com/Alfa-Romeo/B1040-64 https://www.dtcdecode.com/Alfa-Romeo/U2062-87)
B1040-64 - Communication with Body Computer (BCM/NBC) - Signal/message plausibility
U2062-87 - Error in communication with Instrument Cluster (IPC/NQS) - Missing message
Comfort rear seat (CRSM) Bitron - nonexistent
Climate control / CSWM (Comfort Seat and Wheel Module)
Comfort seat and wheel (CSWM) Bitron
Climate control / HVAC (Heating Ventilation Air Conditioning)
TRW climate control (Automatic)
Other / AFLS/NFA (Self-adaptive Headlamps Module)
Automotive Lighting adaptive headlights
Other / LBSS (Left Blind Spot Sensor)
Blind Spot Sensor Autoliv (Left)
Other / RBSS (Right Blind Spot Sensor)
Blind Spot Sensor Autoliv (Right)
Other / PAM/NSP (Parking Sensors Module)
Parking control Bosch
chrener
Post by chrener »
MES can scan only modules really installed in car...
Whats your car production year?
Urea is in newest models 2021+...
Torque vectoring module is only in QV models...
Amplifier is only in cars with premium music...
ETC
For your information MES knows about 100 modules, but they cant be instelled in one car all together....
dusan147
Post by dusan147 »
Yes, it can be logical explanation... My Giulia (2.2, Veloce, Q4, AT8, ) is from December, 2017.
How look listed errors?
I found formal explanation for them on https://www.dtcdecode.com/Alfa-Romeo.
They appear after any driving.
I delete them and they appear again.
