No ECU response!?
Posted: 11 May 2010, 14:44
by twinny156
Hello! Having annoying issues!
- Installed program fine
- KKL FTDI drivers installed
- Correct COM found by program
= Error message "No ECU response" Car is in MAR ofcourse, key on.
Have tried multiple COMS, latency settings and so on. Grrr..
Car is an Alfa 156 year 2000.
When I plug in the USB KKL Windows 7 recognizes the USB serial but also a mass storage device? Cannot find any drivers for this, are they at all necessary?
Any ideas whos the culprit?
Re: No ECU response!?
Posted: 13 May 2010, 19:56
by twinny156
ok, the mass storage device was a card reader, non-related.
tested again today. No success - Checked all fuses all good.
Can my ECU be faulty somehow?
Posted: 14 May 2010, 03:41
by aderolee
I have the same problem to read the ECU flash by my Audi A4 2.0 TDI DPF -2007, ECU Info Data read OK !!but error read flash-data from ECU. I have installed evoscan on two other computers and never had a problem. However one is no longer working due to a processor failure and the other is no longer mobile due to a laptop case failure.
Posted: 15 May 2010, 20:04
by twinny156
Solved!
Windows told me that FTDI drivers where installed. This was true, but only Alfadiag told me that it was missing the FTD2XX.dll for the K-line to run.
Installed the earlier driver setup executable. All is now sweet. :mrgreen:
