Hello! Having annoying issues!
- Installed program fine
- KKL FTDI drivers installed
- Correct COM found by program
= Error message "No ECU response" Car is in MAR ofcourse, key on.
Have tried multiple COMS, latency settings and so on. Grrr..
Car is an Alfa 156 year 2000.
When I plug in the USB KKL Windows 7 recognizes the USB serial but also a mass storage device? Cannot find any drivers for this, are they at all necessary?
Any ideas whos the culprit?
No ECU response!?
Re: No ECU response!?
ok, the mass storage device was a card reader, non-related.
tested again today. No success - Checked all fuses all good.
Can my ECU be faulty somehow?
I have the same problem to read the ECU flash by my Audi A4 2.0 TDI DPF -2007, ECU Info Data read OK !!but error read flash-data from ECU. I have installed evoscan on two other computers and never had a problem. However one is no longer working due to a processor failure and the other is no longer mobile due to a laptop case failure.
Adero Lee loves this forum
Solved!
Windows told me that FTDI drivers where installed. This was true, but only Alfadiag told me that it was missing the FTD2XX.dll for the K-line to run.
Installed the earlier driver setup executable. All is now sweet.
