Giulia fuel cut off reset
Riverside
Post by Riverside »
Hi, I have updated to the newest paid software version 4.8 and I am trying to do a fuel inertia switch reset on a 2019 Giulia 2.0 petrol after airbags have deployed. However because the vehicle has SGW module the procedure will not work. Is there an update to fix the issue or is there another way to perform the reset.
Any help would be greatly appreciated
Carl
Re: Giulia fuel cut off reset
If you have SGW then you are going to have to install a SGW Bypass Module to be able to write to any of the vehicle control units.
HeMaN
Post by HeMaN »
the SGW bypass module is a physical module you must install in your car to bypass the canbus network protection
more info here for example (is in Dutch): https://squadra-tuning.nl/obd-tools/sgw-bridge/
you can try this procedure with stalks, might try couple times:
https://www.youtube.com/watch?v=DLkq_uTBpTY
