Multiecuscan interface and adapters
SasaFiatUSA
Post by SasaFiatUSA »
Hi everyone
I would like to ask for suggestion . I have fiat 500 1.4sport 2013 .I curently have a problem with blinking odometer and i am going to perform Proxy aligment with Multiecuscan. I am planing to purchace license for full version but i doin know what cable (Interface ) and adaptors i need to use . I prefer cable instead wi fi
Please advice where and what type adaptors and cable is best solution
Sasa
Re: Multiecuscan interface and adapters
Take a look here: https://www.multiecuscan.net/SupportedVehiclesList.aspx
You say 500 1.4 Sport - This is probably the same as the 1.4 16V T-Jet/MultiAir.
You basically need and ELM or OBDLink SX Interface and adaptor cable A3 (Yellow)
You are quite right in opting for cable vs Bluetooth as whilst Bluetooh is a little more usable cable is far more reliable especially when doing more complicated things like PROXI and Key Programming.
Word of warning regarding ELM interfaces. Many people have had problems with many different cheap Chinese clone interfaces. To my knowledge there are no clone or bad OBDLink interfaces.
Ideally for either you should use one of the recommended distributors: https://www.multiecuscan.net/Distributors.aspx
Doing this also gives you access to their support if you have problems.
