i have Fiat Bravo 1.6 16v Mjet 2014 from 3 months.From two weeks appear some errors in body and other modules,the most important being U1602 - BUS OFF.
This error apear too in Airbag,Instrument panel and Parking control modules.When I enter with MES(latest version) in Proxi alignment ,shows message that everything is OK and don't need alignment.I will show the scan results below:
Continental Airbag (PROXI)
ISO код: EA 07 3D 8A 0D
Hardware serial number Aр2аC: 53437923 - Ver: 11
Software serial number 4р0а4:00202106 - Ver: 0000
Errors found:
U1602 - BUS off
Body Computer Marelli (198)
ISO код: BF 83 0D 0D 31
Hardware serial number BрCа:198T.0200 - Ver: 02
Software serial number 0р4а4:40003810 - Ver: 0800
Errors found:
B1048
U1734
U1602 - CAN communic.: general faulty
B1046 - Противопожарна система за прекъсване на горивото (FIS) от Engine Control Node
U1726 - Модул airbag (NAB)
U1705 - Модул Receiver Radio/Radio Navigator (NRR/RMN)
Instrument Panel Marelli
ISO код: 32 83 AD 86 3D
Hardware serial number 5р0а0:11180001 - Ver: 01
Software serial number 0р4а0:00011126 - Ver: 0225
Errors found:
U1602 - Линия CAN
Parking control Bosch
ISO код: 3E 83 86 04 20
Hardware serial number 0р2а6:3004184 - Ver: 14
Software serial number 1р.а4:4 - Ver: 0100
Errors found:
U1602 - BUS off
The car have Blue and Me/NAV 3 module,but it is not working.In this condition i buy the car.
The CAN line error can't erase.
I saw that the body was once opened, there are traces on the body.I opened it, unsoldered chip 95160 so we could retrieve the security code. This chip has been unsoldered before.
I checked all the fuses, they are all ok.
Where could the problem be?
2014 Fiat Bravo 1.6 Mjet CAN problem
Re: 2014 Fiat Bravo 1.6 Mjet CAN problem
if Blue&Me is not working check if it is disconnected. maybe it's still connected and throws CAN bus errors
abarthmultijet
Disconnect the blue and me plug and perform a proxy allignment, even when mes says allignment is not needed.
