Connection problem
dCop
Connection problem
Post by dCop »
Hi to all!!!
I have problem with connection, Punto 1.3jtd 2014 and Bravo 1.6jtd 2008. Using OBD Direckt multiprotocol usb interface (ELM 327 1.3/1.4/1.4b/2.1), from Fuchs electonics. All test are ok but when trying to connect to engine module its "Can bus error", to body module with yellow (when testing its not compatible with this interface, but it was last year?!) adapter its "Can bus error". Any ideas?
Re: Connection problem
You say was working last year. Was that on a previous release of MES? If so install the earlier/previous release and see if that solves your problem. If it does then inform MES Support.
dCop
Post by dCop »
Yes, on a previous version. Few days ago I have downloaded new and bought license. I will give it a try, thanks.
When you do testing then there is a Send Report button/text at the bottom of the main panel. You can create a report for a good version run and bad version run. That will help diagnosis.
