fiat ducato 250 custom proxi
steva33
Post by steva33 »
Hello volks,
I need help to remove telematics convergence unit in custom proxi,I don`t no where is memory locationsfor this,car is fiat ducato 250 2.3 diesel 2014,and this is picture from MES,any help are welcome.
30 38 32 35 30 31 36 37 35 33 33 4F 55 54 50 55 54 44 4A 49 54 20 13 03 07 6B 10 00 05 02 00 00 00 09 00 00 04 02 00 00 00 C0 40 13 08 20 10 00 21 0A 00 00 17 01 00 00 8C 06 00 02 00 00 10 00 00 01 00 05 04 00 00 00 00 31 00 00 00 00 32 00 41 01 11 21 00 FF 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 1F 00 00 9B 00 00 02 FF
Re: fiat ducato 250 custom proxi
try this one:
30 38 32 35 30 31 36 37 35 33 33 4F 55 54 50 55 54 44 4A 49 54 20 13 03 07 6B 10 00 05 00 00 00 00 09 00 00 04 00 00 00 00 C0 40 13 08 20 10 00 21 0A 00 00 17 01 00 00 8C 06 00 02 00 00 10 00 00 01 00 05 04 00 00 00 00 31 00 00 00 00 32 00 41 01 11 21 00 FF 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 1F 00 00 9B 00 00 02 FF
steva33
Post by steva33 »
thanks but don`t work,any other solution?
have you tried to disconnect your convergence unit and just do proxi? what happens then?
steva33
Post by steva33 »
sorry for late answer
I don`t have telematics convergence unit an diagnostic and in configurations of the car is present and when try to make proxy alignment procedure,bcm node ok,airbag node ok and then MES search for Convergence Lauberhorn but can`t find it because not present
show your FESLog where you were doing proxi
chrener
Post by chrener »
Hi guys!
I need help with Airbag Configuration of DUCATO X250 MY2008.
Originally had drivers airbag only but owner add passenger Airbag with seatbelts and also change the ABG unit...
But it needs to add two airbags in custom proxi configuration... Which byte needs to be changed?
Thanx a lot!
30 38 32 35 30 30 37 32 30 30 30 4F 55 54 50 55 54 2D 4A 49 54 20 08 12 10 4B 00 00 05 09 00 00 04 C1 00 20 08 B1 00 17 05 00 00 90 06 02 00 00 62 02 06 23 32 00 40 34 FF 00 00 00 00 00 00 01 00 15 04 00 00 00 00 7C 00 04 00 00
Ducatovy-kaja
Post by Ducatovy-kaja »
Please do the same. I also installed a passenger airbag, an airbag module, but I don't know what to change in Custom Proxy. Ducato 3.0 year 8/2008
My current proxy
30 38 32 35 30 30 35 37 30 39 34 4F 55 54 50 55 54 2D 4A 49 54 20 08 07 10 6B 90 00 05 09 00 00 04 41 00 00 08 20 00 16 00 00 20 00 06 03 00 00 62 02 06 21 33 00 40 33 FF 00 00 00 00 00 00 01 00 15 04 00 00 00 00 7C 00 A0 00 00
ssf
Post by ssf »
Hello chrener
A curiosity .. I would be willing to activate the external temperature sensor.
They told me that the function is not present for the X250 series but you can manually insert the Byte. It should be n ° 44 and the value to be entered is 90. I see that Byte 90 is present in your proxy. Have you by any chance activated the external temperature sensor?
With a friend of mine who has the software I tried to change Byte n ° 44 but when performing the proxy alignment the body accepts the value but not the instrument panel and I get the "value out of range" error and the temperature is not shown .
Does anyone by any chance know what we're doing wrong?
Ducatovy-kaja
https://youtu.be/gkzZEkSNamE
outdoor temperature byt 44 from 00 to 80
