Alfa Giulia/Stelvio - more characters on cluster display
charlee
Post by charlee »
When replacing the 3,5" instrument cluster with a larger 7", all text like song titles, navigation guidance and contacts are diplayed shortened/incomplete like on the smaller display - with "..."
I suppose that is controlled by the BCM and possibly there is a way to change it in proxi. It would be great to have such a setting.
charlee
Re: Alfa Giulia/Stelvio - more characters on cluster display
Post by charlee »
Has anyone else encountered this problem?
Jaqlis
Post by Jaqlis »
Hello!
Did the same swap (3.5" to 7") to band new Cluster and same problem. But missing ACC info also. ACC works fine, but no info at screen.
early 2018 Giulia Veloce 2.0 No nav
Current Proxy
30 34 36 32 30 30 34 36 31 30 39 4F 55 54 50 55 54 2D 53 49 54 20 17 11 07 4F 0C 40 65 10 40 19 02 0A 00 00 00 80 00 00 00 4B 0C 00 65 10 40 19 02 0A 00 00 00 80 00 00 00 43 5D 2F 01 A9 82 07 F3 54 31 A1 07 40 10 10 0A A3 1E 04 72 00 35 73 14 01 4F 03 34 1D 83 EC 48 07 43 05 00 80 00 0C 4E 00 00 19 04 00 09 02 5B FA 41 06 E5 05 21 20 09 72 14 3D 80 10 01 00 E8 00 A3 10 11 00 3D 49 03 03 12 D9 57 80 00 01 01 00 00 F0 20 08 20 81 0A 00 00 00 00 00 0C 1C 00 00 00 00 30 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jaqlis wrote: 22 Jan 2025, 08:06 Hello!
Current Proxy
this should change cluster display from 3.5" to 7", check if it fixes your problem
30 34 36 32 30 30 34 36 31 30 39 4F 55 54 50 55 54 2D 53 49 54 20 17 11 07 4F 0C 40 65 10 40 19 02 0A 00 00 00 80 00 00 00 4B 0C 00 65 10 40 19 02 0A 00 00 00 80 00 00 00 43 5D 2F 01 A9 82 07 F3 54 31 A1 07 40 10 10 0A A3 1E 04 72 00 35 73 14 01 4F 03 34 1D 83 EC 48 07 43 05 00 80 00 0C 4E 00 00 19 04 00 09 02 5B FA 41 06 E5 05 31 20 09 72 14 3D 80 10 01 00 E8 00 A3 10 11 00 3D 49 03 03 12 D9 57 80 00 01 01 00 00 F0 20 08 20 81 0A 00 00 00 00 00 0C 1C 00 00 00 00 30 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jaqlis
Post by Jaqlis »
Almost there: Now i see full song names but missing still acc info. Lane keep assist works (shows) fine.
is ACC working? can't see anything in proxi what should cause it not to show up.
Jaqlis
Post by Jaqlis »
yes. ACC works like it should. In the pictuse ACC was on also.
I have 2 Errors in Insturment panel U1736-86 and U1736-87
Jaqlis
Post by Jaqlis »
UPdate:
Went to local dealer and they did instrument panel update. That fixed the missing ACC info on top. All working now.
Thank you shpuncik for the proxy code before.
good to know. can you check new cluster SW versions before and after update? you should find those among logs in MES folder.
Edi1
Post by Edi1 »
Hello dear Alfa friends. 🫡
I'm new to the forum. Hope you can help me.
I drive a Stelvio 2.0t 280hp and swapped the speedometer from the 3.5-inch one to the 7.0-inch one. Everything worked fine except that my light settings are no longer saved, like the flashing when locking and coming home. It works once, but after restarting, it resets to zero.
My bytes would be:
30 34 36 33 30 30 32 30 30 33 37 4F 55 54 50 55 54 2D 53 49 54 20 17 09 21 4F 0C 40 65 10 00 19 02 2A 00 00 00 80 40 00 00 4B 0C 00 65 10 00 19 02 0A 00 00 00 80 40 00 00 43 5D 27 01 A9 82 08 D4 54 37 A8 07 40 20 10 0A A7 1E 04 72 00 35 73 14 01 4F 03 34 1D 8B B4 48 2C 43 05 00 80 00 0E 92 00 00 19 04 00 09 00 5E FA 81 06 E5 01 21 00 01 75 14 00 81 10 01 00 CB 00 B3 10 10 00 3D 49 03 03 12 F9 57 00 00 00 01 00 00 80 20 08 18 81 0A 00 00 00 00 00 0E 56 00 00 00 40 B0 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Proxy worked successfully with MES.
Does anyone know this error or can anyone help me? I'm really desperate.
Best regards from beautiful Austria
