Key fob reprogramming US Giulia
Erdemtheman
Post by Erdemtheman »
Is it possible to reprogram a new key for a US Giulia using MES? Or, do I need to take the car and the key to the dealership?
Re: Key fob reprogramming US Giulia
need PIN code which only dealer can supply when connected to car. or locksmith should be able to pull it from car.
Erdemtheman
Thank you. Once I have the PIN, what’s the procedure in MES to reprogram a new (blank) fob? Appreciate the info.
just run MES in Simulation mode and see for yourself under RFHUB. it's pretty straight forward procedure.
however I have tried to program used virginized key and that didn't work, instead used some designated equipment for that. never tried to do it with brand new OEM key though.
Erdemtheman
Awesome. I was just wondering what section key programming was under. Thank you for the info. I have heard that these original fobs are one time programmable so if you mess up the procedure, it’s done.. so I’ve heard.
I will familiarize with simulation first then figure out the rest.
Thank you.
