Alfa 147 Clutch self calibration enable CFC208F (1)
Alfa_147_Sele
Post by Alfa_147_Sele »
I was hoping someone could help with this adjustment procedure as I can't seem to get it to work (or I'm not sure if it has).
The following is necessary for proper execution of this procedure:
- engine temperature > 80°C
- clutch temperature between 20°C and 150°C
- no errors
NOTE: The procedure must be performed in the following sequence:
1. Press the Execute button (engine must be OFF)
2. Start the engine
3. Do a pick-up in 1st gear with the accelerator pressed ~25%
4.
Stop the vehicle after ~300 metres
5. Turn the key OFF, then wait ~10 seconds and turn the key to MAR.
Do I have to drive 300m in 1st gear only? Or do I have to cycle through the gears? 300m in first only with the accelerator pressed 25% is going to produce some high revs!
Also for step 1 after hitting execute do you have to press "Y" and the wait for the success/failure message before proceeding?
I have run this a few times and the Parameter "Gearbox/clutch self-calibration" always say not completed. Should it change to "Correct" as noted on the screen if the procedure is successful?
Thanks in advance for any help.
Tamas_1986
Re: Alfa 147 Clutch self calibration enable CFC208F (1)
Post by Tamas_1986 »
Wow, I had a very similar question about my car (Fiat Punto Grande - Selespeed) but no response so far :( We are in the same boat, I guess.
I think?
1) With engine off means with ignition on / in MAR position
2) Drive the 300m in AUTO mode so the car changes up the gears as the speed increases
