Set Mileage?
Buckster
Set Mileage?
Post by Buckster »
After a Proxi alignment, I now need to increase the mileage on the new display to the higher mileage of the vehicle.
What are the steps and menu options to do this please?
Re: Set Mileage?
Connect to the DASHBOARD and then select the ADJUSTMENTS tab. There you will find "Write Odometer"
WARNING/CAUTION: Ensure you enter the correct mileage/km. The odometer can ONLY be increased so if you enter too high a value then this can not be corrected. Also trying to set 99999999 etc. hoping it will wrap back to 000000000 does not work.
