wrong iso code?
mechtild
wrong iso code?
Post by mechtild »
I have a Stelvio MY 20 12/2020
I get this error when connecting.:
What does it mean?
ECU ISO code: 00 03 50 5F 18
VIN code: ZARPAHDN0L7D
FIAT drawing number: 50559448
Hardware number: A2C11140400
Hardware version: 01
Software number: AR952 HL
Software version: 310C
Homologation number:
Functioning time (EEPROM): 3884
Operating time: 3896
WARNING: Invalid ISO code for selected vehicle system!
Re: wrong iso code?
ISO code for this instrument cluster currently not included in MES database. You can disconnect and press "Send report" so maybe next time it will be included in new MES version.
mechtild
Re: wrong iso code?
Post by mechtild »
So it means I can't use MES with this car?
Or will just not everything work?
Or will it screw things up?
Wanted to enable race mode
Re: wrong iso code?
MES will not connect to an invalid ISO code to provide all the possible functions for that node/unit.
What I now write is NOT PROVEN and only offered asis that my be of possible use/value.
If the node/unit is an engine ECU then I think (but am not sure) it will connect for basic EOBDII (legally required) functions.
Using MES will not cause a problem but you will lack functionality.
You also have the option of trying a different vehicle. Many ECUs are used in different models and selecting a different vehicle can help coax some access/function.
Re: wrong iso code?
mechtild wrote: 25 Mar 2021, 18:21 Thanks
you can use MES and should be able to enable race mode without issue. just as s130 said, if you connect to instrument cluster node some of the adaptations might not work or parameters could show wrong values. other than that fully functional.
PS maybe you could share your proxi in PM. cheers
mechtild
Re: wrong iso code?
Post by mechtild »
Need to manage SGW bypass first
mechtild
Re: wrong iso code?
Post by mechtild »
Managed to bypass SGW
I can connect to body computer and delete errors.
Interestingly when I connect to Proxy alignment I get the error" empty proxy file in body computer (BCM)"
What to do? Wait for an update?
So I also can't send you my current Proxy config...
Did send report in tool anyway
Report shows:
UNKNOWN/UNSUPPORTED
ISO Code: 00 00 60 31 18
VIN code: ZARPAHDN0L7D0
Hardware number: BCMARMM_D01 - Ver: 01
Software number: 04441662010 - Ver: 3216
Using this adapter:
https://www.multiecuscan.it/en-us/multiecuscan-ios-elm-327-wifi-iphone-ios/
Re: wrong iso code?
mechtild wrote: 18 Apr 2021, 15:33 Interestingly when I connect to Proxy alignment I get the error" empty proxy file in body computer (BCM)"
try change some adapter settings, not sure if you can set wifi adapter as high speed. I prefer to use USB adapters - much more reliable.
while proxi says it's empty, you won't be able to do any changes.
mechtild
Re: wrong iso code?
Post by mechtild »
I have just the option to choose high latency mode or not. Nothing changes. With the same module I get ibto the proxy config of a lancia musa.
You are convinced that it's the hardware and not the software? Especially as it's unknown iso code and unsupported what MES tells me about my body computer?
Re: wrong iso code?
mechtild wrote: 20 Apr 2021, 16:54 You are convinced that it's the hardware and not the software? Especially as it's unknown iso code and unsupported what MES tells me about my body computer?
has no effect. just last weak was working on MY20 car with many ISO unknown modules - didn't have any issues.
try to downgrade MES to older version and see what happens then.
