Daytime Running Lights menu not showing after proxi alignment
yurko
Post by yurko »
Fiat Doblo 263 2013 with 1,3 mJet engine.
After Multiecuscan proxi alignment procedure, from body computer menu on dashboard, disappeared item that allows enable and disable DRL's...
Hove I can return it back? Very love this function.
Re: Daytime Running Lights menu not showing after proxi alignment
check in MES folder FESLog file with proxi log and compare with current proxi.
yurko
Post by yurko »
PROXI Alignment Procedure Log:
CAN CONFIGURATION DATA:
4B 00 00 04 00 00 00 00 4B 00 00 04 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4B 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 4B 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00
33 36 32 36 33 30 31 34 30 32 36 4F 55 54 50 55 54 2D 4A 49 54 20 12 01 23 4B 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 84 C0 53 07 7B 00 37 10 23 00 00 04 00 07 00 14 06 0D 05 3C 00 00 00 00 09 10 05 0C 01 00 00 00 19 00 00 00 00 11 02 25 00 00 11 00 00 00 00 06 00 00 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Airbag Node (NAB/ORC)
(Multiecuscan 4.7R1)
25.01.2021 12:51:34
Fiat Doblò (type 263) 1.3 Multijet 16V
Airbag Node (NAB/ORC): EOL Ok
EXECUTING ADJUSTMENT...
Engine type
Old value: Gasoline
New value: Diesel
COMPLETED
Engine type
Old value: Type 2/1.4 16V
New value: Type 3/1.3 Multijet
COMPLETED
Cruise control (from 2009)
Old value: Disabled
New value: Enabled
COMPLETED
Old value: Enabled
New value: Disabled
COMPLETED
Display external temperature on dashboard
Old value: Disabled
New value: Enabled
COMPLETED
PROXI ALIGNMENT PROCEDURE
Writing to module: Dashboard Node (IPC/NQS) FAILED! - Timeout error
FAILED TO EXECUTE
Whenever I try proxy alignment procedure, it ends up with a write error in Dashboard - Timeout error. It's normal? Why it happened?
yurko
Post by yurko »
This is before I try with Proxy alignment:
6B 00 00 04 00 00 00 00 4B 00 00 04 00 00 00 00 09 00 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
6B 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 4B 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00
33 36 32 36 33 30 31 34 30 32 36 4F 55 54 50 55 54 2D 4A 49 54 20 12 01 23 6B 00 00 04 00 00 00 00 09 00 00 04 00 00 00 00 84 C0 73 07 7B 00 37 10 23 00 00 04 00 07 00 14 06 0D 05 3C 00 00 00 00 09 10 05 0C 01 00 00 00 19 00 00 00 00 11 02 25 00 00 11 00 00 00 00 06 00 00 00 00
This is last log that I have:
After first attempt removed radio NRR. It's normal, because I was change it for Chinese Android multimedia.
In this first attempt I try to enable Cruise control after 2009, External temperature sensor and Stop&Start system. After this first proxy alignment, removed DRL control from dashboard menu.
After that, I tried to return the settings as it was, but unfortunately for DRL. All other functions work fine.
yurko
Post by yurko »
shpuncik wrote: 27 Jan 2021, 09:26 check in MES folder FESLog file with proxi log and compare with current proxi.
Ok.
The data is different.
Can I return data from log back?
yurko wrote: 12 Feb 2021, 07:44
Ok.
try byte 44 - change from 53 to 73
yurko
Post by yurko »
shpuncik wrote: 12 Feb 2021, 18:19 try byte 44 - change from 53 to 73
Where I can do it?
Thanks you.
yurko
Post by yurko »
I was fount information how I can changes bytes in the proxy configuration procedure.
Byte 44 about Rear fog lights. 53 is rear fog lights set to only left and 73 set both fog lights.
What other bytes can I try to change for enable Daytime Running Light menu?
yurko
Post by yurko »
Daytime Running Lights menu disappearing is Multiecuscan proxi alignment bug.
Fix it with Alfa OBD.
If anyone is interested what codes I currently have in proxi alignment - let me know.
ahmedhossam
Post by ahmedhossam »
yurko wrote: 27 Feb 2021, 15:19 Daytime Running Lights menu disappearing is Multiecuscan proxi alignment bug.
kindly i need the code and kindly let me know what is alfa OBD.
i need to activate the drl control on/off
