Re-install MES
AF04
Re-install MES
Post by AF04 »
Hi, quick question; I have a Legitimate Registered copy of MES, however my laptop is failing so will I be able to re-install and activate MES on new laptop?
Re: Re-install MES
Yes.
Read the User Guide here on this Help page : http://www.multiecuscan.net/HowToUse.aspx
License Transfer functionality
In case you need to change or re-install your computer you can transfer the license to the new system by using the License Transfer functionality of Multiecuscan.Here is how to use the License Transfer function:1. Open Multiecuscan on the computer where you have license.2. Go to “Register” window and click “Deactivate” button3. The system will generate a Removal Key (see the screenshot below)4. Write down all 3 keys from the Register window – Hardware Key, License Key, Removal Key.5. Install Multiecuscan on the new computer.6. Open Register window and write down the new Hardware Key.7. Go to http://www.multiecuscan.net/TransferLicense.aspx and enter the old data (Hardware Key, License Key, Removal Key) and the new Hardware Key and your email and click “Request License”.8. You will receive an email with the new License Key.
Multiecuscan User GuidePage 12 of 63 If you have any problems with the License Transfer function you can send us an email with the new Hardware Key to support@multiecuscan.net.Please note that the License Transfer function has a limitation on the number of transfers
AF04
Re: Re-install MES
Post by AF04 »
Thank you for the comprehensive reply, can now add new laptop to my Christmas list. :P
