How it's possible sgw bypass for make proxy Alignment
didi_du_93000
Post by didi_du_93000 »
All in title.
How to make proxy alignment when we use bypass sgw?
When i keep the sgw modul, i can't make proxy Alignment
When i put bypass, i have error on some modul alignment.
So i think it's not possible to make correct proxy alignment when we use bypass.
Anyone can confirm?
Re: How it's possible sgw bypass for make proxy Alignment
Proxi alignment works fine with bypass installed. Check your cable or SGW bypass itself - there were some problems with early versions.
