Does someone have wiring diagram of the BCM as I want to connect external temperature sender on Lancia Ypsilon MY2012?
And how to activate this function, in the coding list I don't see temperature sensor enablement. In the display I don't see --- as the car from factory is without this sensor.
Lancia Ypsilon MY2012 external temperature sender
Re: Lancia Ypsilon MY2012 external temperature sender
hallo, you connected to connector B (body computer) at 52 and 37 the temperature sensor in to left mirror
It seems on all Silver editions central harness is same and it contains wires for temperature sensors, demister and mirrors adjustment. I bought second hand left and right doors wiring harnesses and the electrical mirrors with demister and all started to work. For temperature sensor you need to do PROXI configuration.
Hey guys, for lancia Ypsilon 2007, how do i enable temperature sensor on dashboard because i can t... Please help, i also bought controls and right side mirror, how can i enable it on dashboard?
