Fiat Ducato MultiJet - Finding the right model
miol@outlook.com
Post by miol@outlook.com »
I'm a bit confused - how to select the right vechicle model.
I have a Fiat Ducato 250 MultiJet 2,3. When I select the model (facelift) I get an error telling me, that the ISO code is wrong and that a "Marelli 9DF CF6/EOBD Diesel Injection (2.3)" was discovered. When I look in the vechicle list, this engine belong to the 290-version of the Fiat Ducato program. Is the list wrong and should I just pretend that it is the 290-model?
Re: Fiat Ducato MultiJet - Finding the right model
Use the 290 model version and see how you get on. Hopefully you will get a valid ISO code. If not I think you should still be able to proceed on either the 250 or 290 model selection BUT I WOULD NOT attempt a PROXI alignment procedures with invalid ISO codes just to be on the safe side.
the1andonly
Post by the1andonly »
the X290 was introduced in the summer of 2014
If yours was registered in 2018 it is a x290 euro 6 (manufactured late 2016 for 2017 models)
look at wikipedia and you will see the different front ends
If you connect with MES and do a scan.
My x290 2017 modl reg 2018
Scan vehicle for available modules and check each module for errors...
Engine / ECM
Marelli 9DF CF6/EOBD Diesel Injection (2.3) :D
ISO Code: 00 01 50 08 14
Body Computer Marelli (290)
ISO Code: BF 83 8F 0D B3
ABS / ABS/BSM (Brake System Module)
Bosch ABS 9
ISO Code: EC 07 2F 0D 04
VEHICLE SCAN REPORT
Scanning ...
Engine / ECM
Bosch ABS 9
COMPLETED
VEHICLE MAKE: fiat
VEHICLE MODEL: ducato
VEHICLE YEAR:
if you connect to the engine control module press F10 to connect weather you select 8DF or 9DF it will return the one you have
(Multiecuscan 4.5)
01/11/2020 23:19:06
Fiat Ducato (type 290) 2.3 Multijet
Hope this helps
