Alfa 159 DPF- oil change procedure fail
gio.ale
Post by gio.ale »
I'm trying to execute the oil change procedure on my alfa 159 2.0 jtdm.
I can get a stable connection to the ECU but the procedure FAIL.
I'm using the latest version of multiecuscan, just purchased two days ago.
Do you have any suggestions?
Is there a debugging mode in order to have a verbose logging?
regards
Alessandro Giorcelli
gio.ale
Re: Alfa 159 DPF- oil change procedure fail
Post by gio.ale »
Solved.
The procedure must be run with engine stopped but with KEY in the ON position.
