Want to buy registered version BUT...
Jerry 159
Post by Jerry 159 »
Yani,
I want to buy the registered version of your great software.
But before buying I want know if SERVICE RESET for 159 will be available in future versions?
Otherwise I`m buying a service reset tool.
Please advice,
Jerry
Re: Want to buy registered version BUT...
Service Inerval Reset for Alfa 159 and also for Fiat Croma'05 (I saw someone else asking for it) are already implemented in version 2.2.
This version, however, will be available after 15-20 days.
tonton69
Post by tonton69 »
hI yANI
For reset interval service and fap regeneration will we need elm 327 cable or VAG cable?
thanks
tonton69 wrote:hI yANI
thanks
I'm 100% certain the service interval is ELM 327 / CAN interface only.
fap (I'm assuming you mean DPF Filter regeneration) is on KKL and CAN I believe.
Till manufacturers harmonize on a common protocol/interface them I think both ELM/CAN and KKL interfaces will be required if you want to cover general engine OBD (CAN or KKL), CAN specific (e.g. service reset, aircon, satnav....) and KKL for ABS and Airbag systems.
I suggest you identify what your major need is and initially buy appropriately.
Simple KKL will cover most engine, airbag and EBS systems but will certainly NOT cover service interval resets on modern Fiats.
mojstermiha
Post by mojstermiha »
Will be service reset option only in registered version or also in free version ? (I'm waiting for Croma service reset)
Best regards
Jerry 159
Post by Jerry 159 »
yani wrote:Hi,
GREAT!!!! will put my money on your 2.2 version then!
luks
Post by luks »
can you add service reset (oil change interval) for Fiat Multipla 1.9 multijet 2007, to next version ?
where i should find those option in menu ?
if i know, this option works only on elm 327 ?
luks wrote:can you add service reset (oil change interval) for Fiat Multipla 1.9 multijet 2007, to next version ?
I don't think that you need a software to reset it on Multipla:
Proceed as follows to reset service:
- turn panel on
- press the "MODE" button on the instrument cluster until the word MENU appears on the multipurpoase screen
- scroll items using the "+" and "-" until "MANUT. PROGR." appears on the screen
- press the "MODE" button again, "MANUT. PROGR. + TYRE PRESSURE" will appear on the screen
- identify item "MANUT. TRA" using the "+" and "-" keys
- press the "+" and "-" keys simultaneously for 20 seconds until "2000 Km" appears"
- turn of the panel;
luks
Post by luks »
no, it is not full reset. in multipla with dpf after oil change is nessesary to reset interval by examiner. if you don't do this oil pressure lamp will blink after one minute after turn on engine. after next minute this lamp stop blinking but in service manual I read that i need go to service.
rubberfingers
Post by rubberfingers »
Hi can anyone confirm if the oil change counter can be reset for the Fiat Multipla 1.9 multijet 2007 with DPF using this tool and if so which version?
thanks
