Cantiecar and Multiecuscan 4.6R1
Stardust
Post by Stardust »
Good morning,
last friday i tried to do diagnosis on Fiat 500X but i can connect only to engine ecu for the rest ecus appears on display that needs adapter 6, i thought
that cantiecar interface didn't need adapters or i'm in fault?
Re: Cantiecar and Multiecuscan 4.6R1
Not sure that you are at fault.
I suspect your Cantiecar interface may need a firmware update? The 500X was a new Fiat model that require a new A6 adapter.
Suggest you contact Cantiecar (http://www.tiecar.net/) directly and ask for clarification.
