CSV export data timing
Juraj187
Post by Juraj187 »
When I select all parametres on Brera 2,4 make a test drive and export data to csv file. I have data onle in 20 second interval. Is possible to change export timing to 1secong interval or less than 1 second? I cant find any settings for this.
Thank you
Jiri
Re: CSV export data timing
On the Graph Tab there is a RATE selection below the graph area. This can be set to MAX or any of the other values listed.
The problem is that you have selected ALL parameters so MES is trying to read and plot everything which will take it considerable time to do.
Reduce the number of parameters selected to monitor and graph to the minimum your require to monitor and diagnose any given problem.
