Fiat Bravo 198 Blue & Me durch Android ersetzt. KM blinkt.
Fiat_OWL
Post by Fiat_OWL »
I would like to do a proxy alignment, because the blu & me has been replaced by an android.
Car is a fiat bravo 198, 2010 103 kw 1.4.
The kilometer display flashes.
The connection to the car is established. In the "Can Setup Proxi" are 4 removed modules reported. Is this a problem?
This modules are "removed" ecm / ncm, eps / nge, abs / bsm / nfr and nyl.
Can i make an alignment??
I think "Bravo 07 1.4 Turbo 16V ist the correct selection?
I had already commissioned two fiat dealers who could not solve it :-(
Thanks and regards
Re: Fiat Bravo 198 Blue & Me durch Android ersetzt. KM blinkt.
If those modules are show as removed most likely there is problem in wiring. If you will make proxi alignment most likely you won't be able to start car.
