Hello. After installing the new version of the program I have a problem with the interface. In the attachment photo from the program. Someone has an idea from a colleague. I will add that on version 4.4 it worked normally.
Reports that connection failed. "Method not found: Boolean System.threading.waithandle.waitone(int32)"
Any ideas
Multiecuscan problem interface
Re: Multiecuscan problem interface
Hello, i have got the same problem. System worked fine with MES 4.4.
Version MES 4.7 cannot connect and gives this message.
Did you find a solution so far?
I had same problem.
I installed latest drivers for elm 327 based on CH340T chip (http://www.wch.cn/download/CH341SER_ZIP.html)
I reinstalled NetFramewrok 2.0 and unisntalled NetFramework 3.5.
Now everything runs as good as on old 4.4 MES.
My Multiecuscan 4.7R1 runs on windows XP laptop.
I had same problem.
Hallo Iedereen
Welke is nu de beste interface voor alfa 159
Mvg
Mvg
