Alfa 156 Xenon full-MES Support
blackyman7
Post by blackyman7 »
I used a trial version of MES (4.2) to connect to my 156's OEM Xenon (Bosch AL).
Using the VAGCOM KKL and the yellow plug , the scan could find one ECU , but I can connect to both, even in Trial mode.
Both have proper codes and mfg dates so definitely not random values.
On both screens, in trial mode, I could only see the Info and Graph tabs, not parameters or actuators, although they are supposed to be working in the full version.
Can someone confirm that the full version will show the advanced settings and actuators (ie height, or any self tests ?) ?
Thanks !
Re: Alfa 156 Xenon full-MES Support
you can run MES in simulation mode or check https://www.multiecuscan.net/SupportedVehiclesList.aspx what is possible to do with module
