<t>hello, is it possible to use the multiscan to change the tpms values of a fiat ducato? example in the on-board computer from 5.5 bar to 4.5 bar?<br/>
<br/>
Dieter</t>
Yes but it depends on the model of Ducato.
Why don't you download and install MES. This is free to do. You can then run the program in "Simulate" mode. You then choose your vehicle and explore all functions that are available if you have a license. The TPMS is under the "Other" system and then "TPMS". Then you need the "Adjustments" tab.
