STILO - Marelli MF Body Computer
Godzzi
Post by Godzzi »
hello.
I am curious what can be accesed in this ECU via CAN. For my stilo this is the only thing that will be different in the registered software vs the free one.
Good Luck !
Re: STILO - Marelli MF Body Computer
This is a list of all functions of Marelli Body Computer
PARAMETERS:
Brake fluid level
Brake light switch
Brake lights fuse
Brake wear alarm light
Handbrake switch
Driver door
Passenger door
Rear left door
Rear right door
Bonnet
Boot lid
Boot unlock enable signal
Boot open. switch negative
Boot lock enable signal
Low beam
High beam
Fog lights
Rear fog lights
Reverse light signal
Hazard lights
Side lights
Automatic light switch-on
Turn signal: LEFT
Turn signal: RIGHT
Light washer
Ceiling light
Left map light
Right map light
Heated rear window
Ignition Key on/off
Transponder comm. line
Data from Engine ECU
Immo coded by
Immo ECU status
Code from engine ECU
Engine ECU status
# of programmed keys
# of disabled keys
Last key #
Latest used key ID
# of stored remote controls
Latest used remote control
Last used remote control ID
Remote control battery
Doors lock remote control button
Doors unlock remote control button
Trunk unlock remote control button
Alarm mode
ACTUATORS:
Left side lights
Right side lights
Low beam
High beam
Fog lights
Rear fog lights (Left)
Rear fog lights (Right)
Turn signal: LEFT
Turn signal: RIGHT
Emergency blinkers led
Heated rear window led
Boot open
Boot window open
Number plate light (left)
Number plate light (right)
Compartment/boot lighting
Dashboard lighting (air cond., ash)
Front interior light
Map light (left)
Map light (right)
Dashboard acoustic alarm
Panoramic sunroof
Anti-theft indicator light
Left Brake ligth
Right Brake ligth
Light washer
Aux. relay
Alarm siren serial line check
Volumetric sensor check
Tilt sensor check
Activate alarm
Dusk and rain sensors check
Window wash system check
sa80libero
Post by sa80libero »
potersti aggiungere la disabilitazione cicalino (bip bip) delle cinture di sicurezza?
pr_00f
Post by pr_00f »
English ?
Club Alfa Romeo Bulgaria member / Lancia Club Bulgaria member
Lancia Lybra 2.4 JTD@140 Hp 2001
mattydr67
Post by mattydr67 »
he wants to say that he can stop the bip did it when you don't put your seatbelt.
mattydr67 wrote:he wants to say that he can stop the bip did it when you don't put your seatbelt.
That is actually a function of the dashboard ecu.
And, yes, I will add it soon. As well as activation/deactivation of the emergency blinkers when locking/unlocking the doors with the remote control.
topogatto
Post by topogatto »
You're a genius! 8-)
FES is a must for any owner of Fiat's cars! ;)
Thanks for all!
'03 Fiat Stilo MultiWagon 1.9 JTD Dynamic
sa80libero
sarebbe veramente fantastico poter disabilitare il bip delle cinture di sicurezza....
attendo con ansia la nuova versione con questa funzione...
grazie
mihaitza83
Post by mihaitza83 »
waiting for this function to be available:
"As well as activation/deactivation of the emergency blinkers when locking/unlocking the doors with the remote control."
i have mounted a pear of remotes in my car and i didn't connect the wire that has this function because i didn't find where to connect it..
with this function i can have the function that i need :D
JTD
Post by JTD »
Hy, Yani,
I want to ask you a question for this kind of setting/parameter:
# of disabled keys
Do you know exactly what this means?
And if you know the answer i want to ask you how to erase/reset this parameter to "0" -> "number of disabled keys = 0".
Now i have this to "1" and when i want to program a "new" (old one) key, the board computer say that this key is disabled, and program process failed.
Thanks.
