I'm having trouble performing a calibration after fitting Xenon headlamps to my 159. I have sensor readings from both front and rear sensors, the actuators operate correctly and put both lamps in low middle and high positions. There are no error codes but every time I try to do a calibration it fails. Any ideas what else could be causing this?
Alfa 159 Xenon headlamp calibration
Re: Alfa 159 Xenon headlamp calibration
I have the exact same issue. The actuators operate correctly but the calibration fails, without any error codes or messages. It just "fails". Any suggestions?
I am using an adapter with the KKL interface.
It should be noted that Multiecuscan is unable to connect to one of my headlamps, only the master headlamp seems to work. Might this be an issue?
Mine connects to both headlamps although all you can do with the slave is operate the actuators.
Are you able to run the calibration now, or are you having the same issues as in January?mirafioriman wrote: ↑08 Jun 2020, 19:33 Mine connects to both headlamps although all you can do with the slave is operate the actuators.
Haven't tried it recently but no I've never successfully managed to complete the calibration.
