Grande Punto Proxy Alignment
GP199GER
Post by GP199GER »
Hello there!
I´m trying to retrofit cruise control to my Grande Punto 1.2 8V 2009 Dynamic. I´ve installed the steering column switch and tried to programm it with MES 4.5. Under proxy alignment i´ve enabled the cruise control >2009 and did a proxy alignment. No errors there. Flashing works with my new OBDLink Xs. The Cruise Control Light will light up if i enable it with MES. But the cruise control ain´t working. No LED in the dash lighting up or the dash showing the cc is on. Might there by anything software related or does anybody know more about this topic?
Kind regards
Re: Grande Punto Proxy Alignment
check for any errors in engine, body ecus
leoerqui
Post by leoerqui »
Can you solve the problem?
BrianGlawn
Post by BrianGlawn »
Well first off, are you having a bad connection with the proxy...?
If so, might be a good idea to start a topic about your connection to the proxy in the tech support forum.
