Would add the options to activate the cruise control.
Cruise control works, but not turn the light on the dashboard. I noticed that the FES (when connected to Engine ECU) shows that I do not have cruise control.
BAS
Feature Request: Cruise Control
Re: Feature Request: Cruise Control
What's new?
BAS
BAS
Which make/model/engine is your car?
I added "Cruise control re-learn" function to EDC15C7 in version 2.3.
After re-learning the engine ECU shows that it has cruise control function installed, but, unfortunately, the light on the dasboard still doesn't work. I think it also needs the proxy alignment function to make the body computer recognise the presense of cruise control.
Fiat/Stilo/1.6 16V 103KM.yani wrote:Which make/model/engine is your car?
BAS
This problem is now resolved.
I already tested it on my Stilo and the cruise control light on dashboard WORKS!!! It also shows message "Cruise Control ON" on the display when you turn on the cruise control...
Unfortunately, you will have to wait for next release...
Cool, I can not wait, can you send me an email beta version?yani wrote:Unfortunately, you will have to wait for next release...
BAS
Will this be also possible to install on Alfa 159?
Hi! I know now that on Alfa 159 JTD 1.9 the cruise control can be aftermarket build and it works. The only thing that do not work is that it is not shown on head-unit as described before.
Is this already working now or. will it be present in future versions for Alfa 159?
TNX for great program
Unfortunately, this function works ONLY on Stilo.
I discovered how to turn it on by trial and error. It will not be available for other models in the next version.
To make it work for 159 I will need CAN Info reports from Alfa 159 with and without Cruise Control and then I will have to make a number of tests with a 159...
Hmmm. too bad. I hope you will be able to find some option in the future.
