I described the problem here: viewtopic.php?f=3&t=668
I tried to reset using 2.1REGISTERED, but still I have the same problem.
Any idea?
BAS
Service interval reset stilo 1.6 2005 problem
Re: Service interval reset stilo 1.6 2005 problem
This is not a problem.
The number of service tickets in Stilo is limited to a given number. I think it was 8 or 9, but I'm not sure. There is almost no documentation about this function.
When you make more services than this number the service function is disabled and does not bother you anymore.
I have the same result on my Stilo.
Do you think that it is possible for example to reset this tickets in fiat service?yani wrote:Hi,
BAS
I couldn't find such a function in the Examiner, so it is not possible in official service.
If someone could reprogram the EEPROM inside the Dashboard... then it should be possible.
Is this also for Alfa 159 or just for Fiat Stilo?yani wrote:Hi,
I think it is for all Fiat, Alfa, Lancia models.Jerry 159 wrote: Is this also for Alfa 159 or just for Fiat Stilo?
