Hi Folks!
I have a Fiat 500 from 2016 with a retrofitted 7" Uconnect device.
I've in the BCM code: B10AA-4A Proxy configuration
And in ETM: B222C Configuration
As expected i can't do the alignment cause of the wrong proxi settings.
Does anyone know where i need to change the proxi?
33 32 31 35 30 30 32 34 33 38 37 4F 55 54 50 55 54 44 4A 49 54 20 16 12 01 4F 80 00 04 10 00 00 00 09 00 00 04 10 00 00 00 83 C2 73 06 F4 00 1C C0 00 00 00 16 00 01 00 94 06 01 01 00 40 00 81 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 61 03 08 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8C 00 94 08 52 00 04 88 02 00 20 80 00 00 44 00 97 00 0F 00 00 00 00 01 00 C0 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00
Is the custom proxy
Thanks in advance!
Solved: Uconnect retrofit
Re: Uconnect retrofit
The problem is solved.
Solution:
My Proxy had a lenght of 157 bytes if you change byte length to 193 bytes the proxy alignment will be succesful. Just add 00 til you reach 193 bytes.
Byte 115= 02
Byte 121= 40 Navi
Byte 121= 44 Navi+Audio
Byte 123= D5 Dab
Byte 130= 01 Fiat logo
Byte 130= 05 Abarth logo
Byte 148= 05 Uconnect 7
Carplay, Android:
Byte 157= 01 CarPlay
Byte 158= 00
Byte 159= 00
Byte 160= 01 Android Auto
Solution:
Byte 115= 02
Byte 121= 40 Navi
Byte 123= D5 Dab
Carplay, Android:
Byte 158= 00
Byte 159= 00
Helloeefo88 wrote: ↑11 Nov 2019, 10:53 The problem is solved.
Solution:
Byte 115= 02
Byte 121= 40 Navi
Byte 123= D5 Dab
Carplay, Android:
Byte 158= 00
Byte 159= 00
how do I do abarth instead of opening logo fiat my car fiat tipo
good afternoon i have a fiat 500 from 2016 with uconnetc 5, but i purchased a uconnet 7 with dab / nav and carplay.eefo88 wrote: ↑11 Nov 2019, 10:53 The problem is solved.
Solution:
Byte 115= 02
Byte 121= 40 Navi
Byte 123= D5 Dab
Carplay, Android:
Byte 158= 00
Byte 159= 00
everything was fine when I rode it, except for the km flashing.
I went to a workshop to do the proxy alignment and the guy made some changes and I was without nav / dab and carplay.
can someone here on the forum share the proxy with the functions to have dab / nav carplay again ??????
please please......
