Welcome
Welcome
Welcome to the Support section for licensed users at multiecuscan forum.
Here, the users who have purchased a license, can post any topics.
I will read and respond to these topics with higher priority.
Regards,
Regards,
Re: Welcome
ciao ho acquistato la versione registrata, ho provato il programma in modo simulazione (ctrl-f10) ho visto che le varie descrizioni dell'errore sono in inglese anche se ho selezionato italiano nelle impostazioni, e possibile avere le descrizioni degli errori in italiano?
per grande punto quando sarà disponibile?
complimenti per il programma, e ottimo.
attendo risposta grazie.
Re: Welcome
Hi,In English:
Hello I purchased the registered version, I tried the program in simulation mode (CTRL-F10) I saw that the various descriptions of the error are in English even though I selected Italian settings, and can be error descriptions in Italian?
for great point when it is available?
compliments for the program, and excellent.
waiting for reply thanks.
The translation is for Error names, Parameter names, Actuator names and Adjustment Names only.
The detailed descriptions of error codes, parameters, actuators, adjustments will remain in english.
I don't have plans for translation of those detailed descriptions yet.
Regards,
Re: Welcome
grazie per la rapida risposta.
un ultima cosa.... per il supporto grande punto?
Re: Welcome
Yes, I'm working on the Grande Punto support,
but it uses different protocol than the rest of the cars
and will take me some time to do it.
Probably a month.
Probably a month.
Re: Welcome
ok grazie per avermi risposto.
buon lavoro.
buon lavoro.
Re: Welcome
Hi, I have a Ducati 3.0 160 Diesel Engine. The New x250 Year 2008.
So I tried the 2.8 version, but the software sad, not the right ISO. I replayed with the Y button.
Do you have a update for the new Ducati? The 3.0JTD is not working.
Thanks for your fast help.
Regards
Addi
Regards
Addi
Re: Welcome
Implementing would be pleasant thing the Fiat Ducato version 250.Knaus wrote:Hi, I have a Ducati 3.0 160 Diesel Engine. The New x250 Year 2008.
Regards
Addi
Regards
Beppe
Re: Welcome
Hi Yani i buy your software ..work very well on my Alfa 147 Mjet '03...and interface elm v1.4...great !!
I have a question.... on next version can you support Lancia Phedra 2200 ???
Re: Welcome
hi yani
i have a stilo 1.6 16v 2003 with a bad engine ecu iaw5nft1 , is there a way to place a used ecu permanent to this car
i have electrical code,s of both iaw5,s
i did ride with other ecu for day now ,using the emergency procedure (code via trottle pendall)
(emergency input funtion not to do with fes ???)
now i want to replace the engine ecu with the used one if possible???
thanx wilco1v
thanx wilco1v
