Hello guys,
Punto Evo 1,4 8V ...the Blue and Me is dead and now we want to remove it from proxy, normal alugment fail ...does anyone now which bites we have to change to get a successful aligment ?
Punto 199 / BJ.2012 Blue&Me removal
Re: Punto 199 / BJ.2012 Blue&Me removal
I've managed to remove the Blue&Me module and stop the blinking odometer on a 2012 Alfa Giulietta.
I think the most important thing is to disconnect the battery before removing the Blue&Me module from the CAN bus network. I reckon this applies to all modules which are removed from the CAN network, like headunits/radio's etc.
I removed the Blue&Me unit without disconnecting the battery at first. It resulted in a permanent fault code in the body computer which (among others) leads to a blinking odometer. The fault code couldn't be cleared. Then I reconnected the blue and me module and cleared the fault codes. Finally I disconnected the battery and the blue and me module. After reconnecting the battery I could clear all fault codes in the body computer and the blinking of the odometer stopped.
Please see my video on youtube: https://www.youtube.com/watch?v=RD__7upfeaw
Hello, if removed without disconnect the battery, when re connect the B&m the fault code where are for erase?Tony wrote: ↑26 Apr 2020, 08:53 I've managed to remove the Blue&Me module and stop the blinking odometer on a 2012 Alfa Giulietta.
Then disconect the battery remove the b&m and applythe proxy allignament and erase the faultcode?
