renegade from alogen to full led
gianco
Post by gianco »
i have a renegade my 2015 with alogen light.
i had to retrofit oem full led beams of my2019.
to verify that low and high beam can be on at same time,
i done activation on mes, of "xeno lights", and "shutter"
after i done proxy alignement.
now low and high can be on at same time when, switch lever is on high beam.
after i done that, i plugged the led beam only for test.
and it's ok.
BUT:the level aiming of beams on dash panel switch don't work....
it works if i plug the old alogen.
cuold this be, because i done proxy alignement with alogen beams and not led one?
if i do proxy alignement with led fitted it should work?
