Odometer programming for new TFT
NYC Eng
Post by NYC Eng »
I have a 2012 US Abarth and installed a 2015 TFT.
Going through multiecuscan, ECU mileage reading =92,847.8miles
The car has an odometer readout of 97,522miles
- why would the ecu mileage reading differ from the actual miles of the car?
- I did a test and wrote 97,000miles, but the TFT odometer displayed 97,020miles. After driving 35miles, the odometer says 97,055miles and the instrument cluster ecu reads 97,034.6miles
- why did it write 20miles higher? How do I write the correct miles? Why does the instrument cluster display a different number than what is registered by the ecu?
- which dashboard module should I select? Instrument Panel Marelli MY12 Or Instrument Panel Marelli TFT ?
- what did I do wrong?
Your help is greatly appreciated.
Re: Odometer programming for new TFT
To my knowledge you have done nothing wrong.
If you read the forums you will find that ECU mileages often differ to odometer mileages. There might be a cause to dig deeper if if say the ECU said 200,000 and the odometer said 25,000 (or the other way round).
Nobody has come up with a 100% definitive explanation as to the differences. Being an European/Italian car it *could* be that the system works in km by default and miles is calculated e.g. 1 km = 1000 pulses and 1.6 or 1.609 or other factor is used to get to the require imperial value.
For legal purposes the odometer is definitive status.
NYC Eng
Post by NYC Eng »
My only issue is that my odometer is still flashing.
Should I have ran a proxy alignment after setting the higher odometer mileage?
Thank you very much!
Odometer flashing is normally associated with a Proxi issue.
I have to state that I've never had a flashing odometer or proxi alignment issue/condition so am not the best person to advise.
The fact that you have changed you TFT would require a proxi alignment I believe. There is the possibility that after doing a proxi alignment that the odometer will still flash. This would then possibly indicate the you need to make a custom settings alignment. This is where devils/dangers can be found as altering proxi data can cause massive issues and even immobilise the vehicle.
mr16valve
Post by mr16valve »
Hi NYC.
I had the same problem when I did the TFT retrofit. No matter what I inputted into the MES value, MES would write 10 miles (exactly) over.
If my car / ECU was 51,000 miles & the new TFT cluster was 49,000 miles - I would "write" 51,000. After the proxy alignment the new TFT would read 51,010.
I did this multiple times and the outcome was always the same.
I would put back in the OEM cluster and drive for (in excess of) 10 miles & then try the procedure again.
Then I inputted 51,090 to have the TFT odometer result of 51,100 miles.
I communicated this with the developers but they could not replicate this problem, but I could.
The only difference between you & I is that I never drove my car with the TFT reading incorrectly; I always swapped back in the OEM cluster.
I think that you will have to extract the mileage the the ECU see & then write that value (-20 miles) into the TFT cluster.
I hope that helps you.
Write yours as Instrument Panel Marelli MY12 (if that was what the original scan had). Even with the TFT I still connect with Marelli MY12.
NYC Eng
Post by NYC Eng »
Thank you for the post!
Yesterday I disconnected the battery for over an hour while I installed some new seats, and after I reconnected it the odometer was no longer flashing.
I’m just happy it’s working out now!
