Fiat Panda Invalid ISO code
EnIgMa
Post by EnIgMa »
first question:
what's not supported on my mother's car?
http://img688.imageshack.us/img688/161/pandam.jpg
i got this using ecuscan 2.0 and an elm 1.3a interface.
If i continue i can read fault codes and sensors, but i didn't want to try actuators test or other things.
it's a fiat new panda 1.2 8v, year 2007.
last question:
what have i to do on the main screen, before connecting to ecu?
do i have to manually choose the Brand/Model//Ecu on the list?
Or, it's just a list of what is supported and when i connect to ecu the software auto-recognize the ecu/car model?
thank you!
EnIgMa
Re: Fiat Panda Invalid ISO code
Post by EnIgMa »
no one? :(
You have to select the correct ECU in the window with ECU list.
If you don't know what is your car's ECU then you can try all 4 options that are listed for your car and the one that does not give you ISO error is the correct one.
EnIgMa
Post by EnIgMa »
Ok, i get it.
