When I connect to my selespeed ecu there are 2 listed ecu's:
Marelli SELESPEED CFC208F (1) Automatic Gearbox
Marelli SELESPEED CFC208F Automatic Gearbox
When I use the first ECU I see under parameters and under adjustments stuff about clutch degradation index.
I do not see this if I connect using the second ecu type. Why?
I need to reset/adjust this value but I get an error (invalid iso code) when I connect using the first ecu type and it will not run the clutch degradation index calculation under adjustments.
Is it correct that it is missing from the ecu type I should be using?
Clutch Degradation Index Alfa147 Selespeed
This is weird. The Clutch slip has gone. Not complaining tho. Will just monitor it.
