Stelvio Proxy Alignment
StokeR
Post by StokeR »
After a failing Proxy Alignment it is not possible to connect to the control units anymore.
One have to reboot windows to connect again.
axy
Re: Stelvio Proxy Alignment
Post by axy »
I am new to Multiecuscan and would like to ask for help for the same issue too.
Can somebody explain maybe a step by step procedure for a proxy alignment for a Stelvio?
Oh yes,and does a next service reset and alignment as well?
Thanks!
axy wrote: 02 Jun 2019, 08:40
Thanks!
Doing a service reset does not do or involve a Proxi Alignment.
axy wrote: 02 Jun 2019, 08:40 Hello,
Thanks!
Have you read the information offered by MES?
"The PROXI Alignment procedure is used to configure the modules connected to the CAN network of the vehicle. A flashing odometer indicates the the PROXI is not aligned properly. If your odometer flashes or you have added/removed/replaced CAN modules from your vehicle then you need to execute this procedure.
NOTE: Please read carefully all data on the "Info" screen. Check if available and configured modules correspond to your vehicle. Also, if the Info screen shows that added or removed ECUs are detected, check if those ECUs are detected correctly.
NOTE: Make sure that your Multiecuscan log files folder is configured properly as the program will write some important information about your current PROXI configuration and you will need to send the log file to the author in case of procedure failure.
WARNING: DO NOT INTERRUPT the procedure once it has started. The key should be at MAR and Engine OFF. After successfull execution of the procedure turn your key to OFF and wait at least 5 seconds before turning it back ON.
NOTE: On some models (GIULIA and STELVIO) the ABS module may be reset during PROXI procedure. You will have to connect to ABS mnodule and perform all calibration procedures."
Brede
Post by Brede »
Hello , i did this alignment with my Giulia, it stopped and asked for a grey cable, i did not have a grey v´cable.
Now the car starts but everything as locked as i can not reach abs / TCM or auto gearbox, its parked in P and wont go out from the P.
Where should i have seen the written information on grey cable ? Is there any links here ?
Is it possible to unlock this vehicle or do the dealer need to do this ?
Thanx for any help.
BRN
kostaki
Post by kostaki »
Brede wrote: 03 Apr 2021, 20:27 Hello , i did this alignment with my Giulia, it stopped and asked for a grey cable, i did not have a grey v´cable.
BRN
Check this page:
https://www.multiecuscan.net/SupportedVehiclesList.aspx
