Hí people , this software of Yani is very good, excellent , but , need add more ECUs old .
When there will be support for old cars ?
Magneti Marelli ECUs :
Fiat groups pre-obd , with connector diagnostic 3 pin ( fiat tester ) Polinski
IAW WEBER SPI single-point system
IAW- 1G7
IAW -SPI G7
IAW -SPI G6
IAW -1AF
IAW -8P
IAW -1ABG
IAW -G7.25
IAW -G7.11
IAW -1AB
FIAT TEMPRA , UNO , FIORINO , PALIO, PUNTO , TIPO , ................
Any plan for it ?
Thanks.
Cars pre-obd ?
Cars pre-obd ?
Re: Cars pre-obd ?
I'm afraid that these ECU will no longer do. I already gave the definition file for 1AF, but no answer from yani was not given, a pity.
Re: Cars pre-obd ?
Hí friend , thank you for your reply .
I am Sorry , sorry , but I am need this program with ECUs olds , my car is Old , Fiat Palio, it is year 1997 !!!!!!
Some idea ?
Thanks.
Some idea ?
Thanks.
Re: Cars pre-obd ?
I've the same problem for a 1996 Punto 90 using the GM ecu (DELCO/MULTEC).
I posted the definitions for the IAW 8P, but i've no informations on my ecu.
Re: Cars pre-obd ?
I am also interested in support for ECU older type 1ab etc, here in Brazil we have many vehicles with this ecu. I would be grateful if the next updates should be possible to add them.Thanks
Re: Cars pre-obd ?
I just want to know if there is even a possibility for IAW 1AF.16 to be included or we shouldn’t count on?
