malzapl I know the solution to our problem.
As your proxi, this string, ends with 160 or even fewer bytes, then add 00 00 00 00 00 until there are 235 bytes.
Then all computers will accept this proxi, ecu radio also.
My factory proxi looks like this:
33 36 33 35 36 30 30 32 32 35 39 4F 55 54 50 55 54 44 4A 49 54 20 16 02 24 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 50 D9 05 01 A4 10 07 8D A0 24 41 07 42 10 00 03 A3 1E 04 02 01 35 43 14 00 01 03 00 00 03 08 00 0C 00 02 00 80 00 00 00 00 00 30 81 00 25 00 5A 00 64 06 A5 00 42 00 05 92 10 00 40 00 01 00 C7 00 D1 00 00 00 00 49 00 01 14 70 42 00 00 00 01 00 00 70 00 01 1C 80 00 C0 00 05 00
So that the radio will play them, you should change them so that it has 235 bytes, that is:
33 36 33 35 36 30 31 31 36 32 39 4F 55 54 50 55 54 44 4A 49 54 20 16 02 24 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 50 D9 05 01 A4 10 07 8D A0 24 41 07 42 10 00 03 A3 1E 04 02 01 35 43 14 00 01 03 00 00 03 08 00 0C 00 02 00 80 00 00 00 00 00 30 81 00 25 00 5A 00 64 06 B5 00 42 00 05 92 10 00 40 00 01 00 C7 00 D1 00 00 00 00 49 00 01 14 70 42 00 00 00 01 00 00 70 00 01 1C 80 00 C0 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
And in Polish, because I can see from the messes logs that you are from Poland:
Znam rozwiązanie naszego problemu.
Jak twoje proxi , ten ciąg znaków, kończy się na 160 czy nawet mniej bajtach, to należy dopisać 00 00 00 00 00 aż będzie bajtów 235.
Wtedy wszystkie komputery przyjmą to proxi, ecu radia również.
Moje fabryczne proxi wygląda tak :
33 36 33 35 36 30 30 32 32 35 39 4F 55 54 50 55 54 44 4A 49 54 20 16 02 24 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 50 D9 05 01 A4 10 07 8D A0 24 41 07 42 10 00 03 A3 1E 04 02 01 35 43 14 00 01 03 00 00 03 08 00 0C 00 02 00 80 00 00 00 00 00 30 81 00 25 00 5A 00 64 06 A5 00 42 00 05 92 10 00 40 00 01 00 C7 00 D1 00 00 00 00 49 00 01 14 70 42 00 00 00 01 00 00 70 00 01 1C 80 00 C0 00 05 00
To żeby radio je wgrało należy je zmenić na takie, aby miało 235 bajtów, czyli :
33 36 33 35 36 30 31 31 36 32 39 4F 55 54 50 55 54 44 4A 49 54 20 16 02 24 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 50 D9 05 01 A4 10 07 8D A0 24 41 07 42 10 00 03 A3 1E 04 02 01 35 43 14 00 01 03 00 00 03 08 00 0C 00 02 00 80 00 00 00 00 00 30 81 00 25 00 5A 00 64 06 B5 00 42 00 05 92 10 00 40 00 01 00 C7 00 D1 00 00 00 00 49 00 01 14 70 42 00 00 00 01 00 00 70 00 01 1C 80 00 C0 00 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Pozdrawiam
