Jeep Renegade 1.6 E-Torq
iamkrzysiek
Post by iamkrzysiek »
I have Jeep Renegade Sport 1.6 E-Torq. (EU ver)
Is this supported model?
Supported vehicles list page (https://www.multiecuscan.net/SupportedVehiclesList.aspx) doesn't include this variant.
There are only listed:
Jeep Renegade 1.4 16V MultiAir
Jeep Renegade 1.6 Multijet 16V
Jeep Renegade 1.8 16V
Jeep Renegade 2.0 Multijet 16V
I want to buy Cruise Control steering panel and enable it in MES. Is it possible?
davidino66
Re: Jeep Renegade 1.6 E-Torq
Post by davidino66 »
I think its possible, if the body computer is the same, but the first Renegade 2015 they had no radar compatible with the ACC. what year is your Jeep??
truemozzer
Post by truemozzer »
I dream of this engine in the new versions of multiecuscan. I have to activate the rear camera, clear climate error in the odometer and more!
iamkrzysiek
davidino66 wrote: 12 Mar 2019, 19:15 I think its possible, if the body computer is the same, but the first Renegade 2015 they had no radar compatible with the ACC. what year is your Jeep??
I have 2017 version.
I have base version, without any radar features.
I want to add traditional passive cruise control by adding buttons on steering wheel:
I don't really know if required wiring and socket is present in wheel for module. Maybe somebody disassembled wheel before?
Of course I know that active cruise control is absolutely not possible because of lack of FCW (forward collision warning) and radar.
I would buy Multiecuscan anyway if 1.6 engine would be available becasue I want to reset service interval.
I tried connecting with demo version selecting Jeep Renegade 1.8 and Fiat 500X 1.6 but ISO mismatch warning displays.
iamkrzysiek
I had:
1) Installed entire steering wheel with CC buttons from another car (wheel wiring is different so solely module isn't enough)
2) Enabled Cruise Control in AlfaOBD (MES is missing 1.6 E-Torq engine)
3) Made PROXY Alignment (ELM327 + blue & gray adapters)
4) It works! :D
Mariano
Post by Mariano »
Hello iamkrzysiek:
I'am triying to do exactly the same that you did with the CC on your Renegade.
I had a Fiat 500X and has similar proxis with Renegade , so I'm triying modifing manually the proxi bytes.
I wanna now if you can help me with a copy of your proxi map after and before the changes that you do with MES to activate Cruise Control.
chrener
Post by chrener »
First you have to check the BCM level...
Send a BCM label photo if it is possible...
Mariano
Post by Mariano »
Thanks cherner for the reply ,¿ How many levels there are?, I tested all bytes (CC-ADAPT-, ETC) on byte 92 , signals to Engine Control, and yes the proble is between NBC and NCM.
chrener
Post by chrener »
If you have L0 on your BCM label, cruise control will not work on your car!
