fiat grande odb auto + yellow adpt not work ?
patrickfax
Post by patrickfax »
Hello Help!!!!!
I have a new odbauto elm 1.3 ( ok compiliant list) , a new A3 cable, this software ( new buy registred 4.3)
MY computer with the good drivers ftdi, 38400 baud ( set like the manual)
impossible to use can proxy set up and all other specific setting ( ask for yellow cable A3 for link it)
the car grande punto 1,3 multijet diesel type 199
All time "fail to connect to the bcm" check your cable and connections ....
i just want to activate the cruse control ( car have juste the speed limit alert) but a new cruse control is fited
I use the proxy aligment /setup option
see the scan result odb and the linck check with <elm 327 = <ok>
Best regards Patrick
Merry XMAS
Moteur / ECM
Marelli 6F3 EOBD Diesel Injection
ISO Code: 68 07 2F 08 FB
Structure / BCM (Body Computer Module)
Body Computer Delphi (955)
ISO Code: 40 83 40 08 E0
ABS / ABS/BSM (Brake System Module)
Bosch ABS 8 ESP (2)
ISO Code: EC 07 08 07 57
Direction assistée / EPS (Electric Steering Module)
Delphi Electric Steering (2)
ISO Code: 31 83 16 08 A7
RESPONSE:
ELM327 v1.5
ELM327 v1.5
>Cette interface est compatible avec ELM 327 1.4! Devrait pouvoir se connecter correctement avec tous les modules CAN.
