Yani, don't you think, that there should be a question, "Are you sure?" before running "Adjustments"(after i choose execute)?
BAS
R U sure?
Re: R U sure?
I just find that kind of question annoying....(i mean: "are you sure?")
If you're not sure or ready to do something....why you should press the button and then press "No" ??
Just don't click on it.
or you're talking about an involuntary action?
Re: R U sure?
That's true.EnIgMa wrote:I just find that kind of question annoying....(i mean: "are you sure?")
I'm talking about an involuntary action.EnIgMa wrote: If you're not sure or ready to do something....why you should press the button and then press "No" ??
Note that F10 in the Adjustments tab means execute but in the Info tab means disconnect.
Yesterday I was going to disconnect (the sun was shining-I didn't saw the display clearly), someone called me and I ended up on autoadaptation reset.
BAS
Re: R U sure?
I have actually implemented an additional confirmation for all "adjustments", but it is not showing for some of the ECUs. That is a bug and will be fixed.
You are right about the F10 key for disconnect. It is a good idea to change it.
