Good day
I have question.
How to force interface ELM to transport from ABS, TRW, Airbag. Stilo 1,9 JTD 16V?. It should was one unite pin so as in VAG?
ELM -> ABS, TRW, Airbag
Re: ELM -> ABS, TRW, Airbag
Good question! I want to know that too. Have you tried without making a bridge?beton wrote:Good day
I have question.
HI,
There is no way to connect without physical connection!
Yes, you need to modify your ELM interface and bridge the pins.
You cannot connect to airbags with ELM. It is a limitation of ELM 327 v1.3.
Thank you Yani. I felt that the ELM327 is much more stable than the KKL, so can I bridge the pins 7 and 1 in my ELM327 to access the ABS? Would it work? I've done that to my KKL interface but not sure I can do it to the ELM.yani wrote:HI,
My ELM327 version is 1.2a, should I bother buying a 1.3 or 1.5?
if you have the 1.2 version wait a little longer and buy a version 1.4 instead.
1.3 is almost old.
1.3 is almost old.
ELM Version 1.5 What is this?
fake/clone version of elm327 1.3 version.
thanks
I find 1.4
I find 1.4
