seat belt beep OFF and ON problem
jcmonteiro
Post by jcmonteiro »
today I tried to switch off and on the seat belt Alarm on my 2012 FIAT 500, but the beep did not come back. I tested the Instrument Panel "beep" and the beep accused but did not stop until switched ignition off. MES gives an error message. ("problem with switching beep" or similar)
Also, I've found a seat belt alarm option in the BCM menu but no matter if I switch it to ON position, the alarm won't come back.
Instrument Cluster:
Marelli TFT (recently retrofitted)
MES 3.1 registered
Thanks for your help,
