Status Codes
Posted: 04 Apr 2010, 18:53
Hi folks,
Could anyone (Yani?) shed some light on the status codes please.
I'm refering to the final message one receives after running one of the possible adjustments i.e.: Line-end, clutch adjustment etc.. The format is Hex but the meaning is what I'm after... So far I couldn't find a legend or any reference...
I'm presently up against a nasty selespeed prob in a Stilo Abarth - irregular loss of entire transmission control without any stored fault. All parameters look as they should and yet - every now and again the transmission fault message comes up (in the car display) locks the box in Neutral - while the ECUScanner suggests that everything is fine. The only difference to scans under functional conditions are the affore mentioned adjustsments. Most of them will - while the fault is present - almost immediatelly result in a hex code and not being carried out - so it would be of some interest to me to understand the meaning of those numbers...
Ah, and yet another question: Does anyone knows a reasonable priced source for a ELM 327 interface? I'm located in Germany and there isn't a single one in the German bay... Next stop is China or Hong Kong, which I'm reluctant to try. There are various sources from the BIg Apple but the last time I tried this I ran into big trouble with German customs... Any suggestions welcome.
Martin
Martin
